I have had problems for awhile. First it keeps turning on and off. I brought it to a couple of Verzion stores. they tell me the same thing, get a refurbished phone or a new one. If I am having problems with my existing phone, what makes them think a refurbished phone will work? Also, I can't afford a new phone. Lately, I can't access the settings. Some applications, say, they have stopped working unexpectedly. I have 2 choices, force close or wait. Neither works very well. I have also removed the battery, as has been suggested at the Verizon stores. This doesn't make the phone work any better. Can anyone really help me?
If you're still dealing with this..have you tried uninstalling your apps or a factory reset? In regards to a refurbed phone..it's noted they may actually be better than a new one. The phone was probably a return. It is then sent to a distribution center where techs get the opportunity to perform updates, fix issues etc.
