Possible solution for Data Connect Issues
I have been going through a number of test to identify the data dropping issues that a number of users have reported and I think I have identifed one possible solution that seems to be working for me, I have ran my device for almost a week like this and I havent had any buffing or connection lost issues and I figure this may be something worth sharing..
Goto Settings / Wireless Networks / Mobile Networks / System Select and change it from auto to Home Only and reboot. this seem to help a lot and I havent notice any issues, but keep in mind if you travel a lot you may have to switch to Auto tp get reception in some areas.
This was just a test and cant say it will work for everyone but it may be worth a try....
This is for the 3g network and I do not think it will effect wifi and since I never had wifi issues it would be hard for me to test that connection. Sorry...
Wildman do think this would work in a 50 to 100 mile radious area like to wichita , to Newton to Mcpherson. if we take a tootle.
thru the week though i'm home so it would'nt be a biggie. some thing els i notice wildman when i'm using the Network an
streaming like Scanner Radio Pro when Birtha is pluged in to the charger it streams flawlissly with a minor hick-up once an
while but if she is off the charger she Buffers like going thru a wind storm or stops all together an she does'nt to bad when were
out tootaling around. around town. or over by McPherson , Newton , Wichita. But one thing wildman i dont thank they.ve got the towers
totally switch over yet the reason why not to long ago i was on the phone with a T 3 Teck an ask if the Call Center were still staffed by
Verizon an Alltel Tecks an he said yes they were but it was going to changed Very Soon an then Alltel would be gone for Good i told
him i was surprized it was still around at all an he said yea there are a few little pocket places but when when all the alltel tecks
finish there Teck Traning an a few loose end's between Verizon an alltell an Alltel an At&t were done the alltel name will Vanish. For
Good.
This has also been reported as a fix by another user in addition to turning off data roaming.
Pool shark is'nt it a he$$ of a deal that there are still Alltel towers in operation in the Verizon aeas even though no alltel stores
exist. when i talked to that T3 teck i said Boy thats a head Scratcher an he said you now how it goes when the Government. has
its fingers in the Mix i said yea gotta makem happy. He said well Verizon Does'nt have much say when Goverment has there
fingers in it. they say you do it this way an he said an thats way it better be done. i said or someone or the company will pay an he
said yes sir. i said i think thats all i need to Know. An i told him thanks for helping me answer my Question an he said No
problem. if you need help on something again give us a call .
Pool shark that post may of just helped me. wildman if you havent checked out that link take a look. in my case i'm about 1.2 mile from one tower an about 0.9 mile from the other woooo no wonder they may be a issue with me being smack dab in the middle of two Towers an the one tower has more than one set of elements wich could lead to another carrier using that tower as well. thank thats possible wildman.
Wildman i done a change an set Birtha to Home only , Data Roaming is unchecked But Backgroud Data is Checked an Data Enable is also checked. So then i need to power birtha off an restart her or is better to do a Batt pull while she's on an restart Her. just want to make sure wich is best. !
Wildman did you here that the LTE may be Down Nation Wide i Heard this erlier. i think thats been the 3 or 4th time
for this that dont sond to good but they may have had too . Do a upgrade or Maintinance on it.
Since no 4g here yet it hasn't got me worrying yet.
Wildman I think Verizon is going to have to buy some Bigger in Diameter Pipe to run more Data cable for the bigger of influx of Data thats going to be pumping thru there system an if they don't its going poop out more an more. as areas come on line as it has already done more than once now . do you think this would be fair to say Wildman.
Wildman are you going to be on net for a while. if so i'll post in accouple hours i'm streaming Tune in Radio off the system. an so far its streaming as it should 3G an 4 Bars Winner Chicken Dinner
i always wanted to say that ![]()
DincX110 wrote:Wildman are you going to be on net for a while. if so i'll post in accouple hours i'm streaming Tune in Radio off the system. an so far its streaming as it should 3G an 4 Bars Winner Chicken Dinner
I use Tune in Radio at work at times.... that and ESPN radio app... one of the two is usually running.
and the correct phrase (at least how I learned it) is "Winner Winner Chicken Dinner"
Curtturp i beleave your Right forgot to stick that other "winner" in there before that chicken Dinner
my mistake thanks for the reminder. ![]()
@ Wildman i streamed music an birtha from 1 to 7 this morning an she did fine the only little mistake i maid i concked out an forgot to plug in the charger an she went untill batt drained so i'm pumping it up again for another test run. O i'm watching some good racing got tony stewart on the pc via race buddy. its cool riding in the car via the camera an the live Audio. Go Tony Go.!...![]()
Glad to here that is working well for you also... I streamed pandora all night myself without issues, the setting seem to help a lot.
Hey wildman i would'nt mind haven a little gal come over the speaker on my droid X as was said in that one post just as long as she does'nt cuss me out.!.........
