Power is on but phone won't work
ppompili
I just tried to change my wall paper using a pic from my gallery, and the phone now will not work. I have power but no display. My green alert light is flashing  and when I called the phone it rang. But I can't get the dispay to come on so I can't call, Power is on but phone won't work
Ann154
Community Leader
Community Leader
Have you tried plugging the battery while the phone is turn on?  Leave the battery out for a minute then re-assemble and power on the phone.
B33
Legend
As Ann said if you can get your phone on by pulling the Battery i would try it an also get rid of the Wallpaper it may be a Rouge/Bad wallpaper.
LatachaM_VZW
Verizon Employee
Hello ppompili,
I would like to thank the community for your great responses. I would like to add you can try running your device in safe mode. Here is the link: http://support.verizonwireless.com/clc/devices/knowledge_base.html?id=35030
Let me know if this helps.
Thanks,
LatachaM_VZW
ppompili
I was able to reset my phone to the manuf. Settings using the process given to me by the verizon tech rep on the phone. The suggestions i received, i had already tried. I wasn't sure how or where to reply. Tell them all thanks!
<< Personal information removed to comply with Verizon Community ToS >>
Message was edited by: Verizon Moderator
ICBM65
I am having this same problem. Turned in first phone and second phone also gets hung up during power on routine. I was told at store that factory reset could not happen b/c phone would not fully power on and screen not visible. Help?
