Spare Battery Charger for Droid X?
So I've been on the hunt for a spare battery (only) charger or a docking station with 2nd battery charger for my Droid X.
I can find some that say they're compatible with the Droid X, but they list a different battery part number than what I've got. I don't know if Motorola changed batteries or what. Most, if not all, the chargers I can find are for a battery with the part number BP6X, which I believe is a Droid 2 battery.
My batteries are BH5X (standard battery) and BH6X (extended battery).
Any and all help is greatly appreciated!!!!
natsad wrote:So are you aware of a standalone battery charger or cradle with 2nd battery slot that will work for the Droid X batteries I have?
Thanks!
This isn't a Motorola product so you take a risk, but I have not seen anything by Motorola that fits your need.
BH5X is the Droid X battery. The BP6X is a different battery, I believe it's the battery the Moto Droid 1 uses. They are different shapes.
I don't know of a battery charger that fits the Droid/droid 2 battery that will also fit the Droid X battery.
Thanks!
Thanks!
Yeah, I just purchased a similar charger from another website http://store.androidcentral.com/mobi-products-cradle-w-spare-battery-slot/5A100A7461.htm. The only draw back that I can see is that you need 2 power sources if you're charging the phone and a battery. We'll see how it goes.
natsad wrote:Yeah, I just purchased a similar charger from another website http://store.androidcentral.com/mobi-products-cradle-w-spare-battery-slot/5A100A7461.htm. The only draw back that I can see is that you need 2 power sources if you're charging the phone and a battery. We'll see how it goes.
I looked at that 2 power sources and didn't think it was much of an issue if you use it at a computer desk. If used elsewhere you could just use the wall charger that shipped with your phone to plug the usb cord into.
