Updated gingerbread- now no led missed call led - any ideas
Have you checked to make sure your settings didn't change?
Hello, I do not think anything changed, where should I be looking ?
In your settings. Call Settings or Sound.
Come to think of it, I've never gotten the LED blinking with just a missed call, only if there was a voicemail left.
Hello stop4it,
There is not a setting in the phone to manage the LED indicator natively. I have tested this on several Droid Xs & the LED indicator does not flash for missed calls. If you would like to have an LED indicator app that can be managed there are several options in the marketplace. Simply search missed calls & there are 3rd party apps that can be downloaded. Keep in mind that 3rd party apps are not supported by Verizon Wireless & I highly recommend reading the reviews prior to downloading.
Hope this helps...
