Hi,
Gmail and Yahoo mail works great; however, I was having trouble with a custom email setup. The problem is with the outgoing email and not the incoming email. I set up an IMAP connection for incoming and it syncs very well. When I try the outgoing, it is unable to send email and there is no error message that could tell me what went wrong.
Settings used for IMAP (and it works):
Server: [connect.wayne.edu]
Port: [993]
Username: [myusername]
Password: [mypassword]
[select] Use secure connection
[unselect] Verify certificate
Settings for outgoing mail that does NOT work:
SMTP server: [connect.wayne.edu]
Port: [587]
The same mail server and port settings works on a co-worker's Droid, which is running perhaps older version of software that allows you to select security option: [TLS] . I think the problem in Droid2 outgoing is this security option.
When I downloaded the "TouchDown" for DROID2 trial version of App (by NitroDesk), the outgoing email works without any trouble. However, I want my fix the email software that came with Droid2.
Regards,
Nadeem
