I have a Droid Turbo 2. My MMS messages as well as pictures will not send to recipients. They just say "sending" but never do. Normal text come and go just fine though. I've tried doing a hard reset, but nothing changed. Please help!
Thank you. I tried changing the settings for data and nothing changed. Then I did what I probably should have done in the first place. lol. I took the battery out for 30 seconds, put it back in, and was able to send and receive pics again. Thanks for trying to help me.
This is happening to me too. Started on or before July 12. I have an LG Vista. My zip code is 31088. Won't send MMS messages even when connected to WiFi. I have not used any data. It is not time for my plan to renew. Shows a message stating I am not connected to the network. Sends and receives SMS messages perfectly. Thanks. Tried to re-send pics that I have sent previously. Doesn't work.
Hello NITTORIDER02! Let's get your MMS messages flowing in again for you. To clarify further, are you able to send/receive regular text messages and or connect to data/internet (when Wi-Fi is off)?
KristieQ_VZWFollow us on Twitter @VZWSupportIf my response answered your question please click the "Correct Answer" button under my response. This ensures others can benefit from our conversation. Thanks in advance for your help with this!!
MMS needs to connect to the Verizon data network to send and receive
WRUser,
Let's get you connected sending your MMS. You can go to Settings/Data Usage. Please make sure your Mobile Data is turned on. Also make sure you do not have Limit Mobile Data Usage turned on. Please toggle these as well and test again.
RobinD_VZWFollow us on Twitter @VZWSupportIf my response answered your question please click the "Correct Answer" button under my response. This ensures others can benefit from our conversation. Thanks in advance for your help with this!!
Oh good. We are glad to see things are back to normal with the picture messages again.
TamaraH_VZWFollow us on Twitter @VZWSupportIf my response answered your question please click the "Correct Answer" button under my response. This ensures others can benefit from our conversation. Thanks in advance for your help with this!!
