Hello Everyone ,
I'm contacting you to ask for assistance with a problem I'm having when using my Verizon Fios cable TV service. I've been experiencing occasional TV signal outages for the last few days. It is quite annoying to watch anything when the screen briefly goes blank and the image reappears. This occurs regularly.
Here is some further background:
- The problem began approximately a week ago. Up until that point, the service was operating flawlessly.
- Despite my repeated attempts, the issue still exists with the set-top box.
- All of the cable connections appear to be secure after I checked them.
- Included in the same plan is internet service that functions flawlessly and without any hiccups.
- In an attempt to help, I tried rebooted the router, but that did not work either.
- The Verizon website indicates that there are no service interruptions in my location, based on my check.
Has anyone else's Fios TV service been affected in a same way? If yes, how did you manage to fix it? Are there any other troubleshooting techniques that I might be overlooking?
I also checked this https://www.verizon.com/business/support/equipment-devices-services/fios-tv-services/minitab/troubleshooting/
Any recommendations or guidance would be much valued. At this point, I don't know what else to attempt, but I'm trying not to require the need for service if at all possible.
Thank you in advance for your help and support.
