As anybody here knows, the thunderbolt isn't exactly a champion when it comes to battery life, however I've been able to use this phone without any inconvenience by keeping a charger with me most places I go. Unfortunately, for the past few days I have noticed that this isn't enough to keep up anymore. While plugged in, the phone continues to lose power if I use it at all (any combination of having the screen on, wifi on, or mobile data on), the battery continues to slowly drain.
I can charge the phone while it's off or by disabling almost everything on it however this is very inconvenient. This is all taking place using the OEM charger though I have tested other chargers to see if there is any improvement (there isn't).
The other day I factory reset the device hoping that this would help however I'm continuing to have the same problems. I installed the 'Current Widget' app this morning and it's reading only ~70mA (average) while charging on AC power.. Has anybody else come across this same issue? Hopefully there is a resolution out there..
