Calls work sporadically, but mostly not at all.
RMJR2, We never want you to miss any calls. We're here to help. When did this problem occur? Let's make sure call forwarding isn't turned on. Please dail *73 send. View more details here: http://www.verizonwireless.com/support/how-to-use-call-forwarding/.
TrinetteW_VZWFollow us on Twitter @VZWSupportIf my response answered your question please click the �Correct Answer� button under my response. This ensures others can benefit from our conversation. Thanks in advance for your help with this!!
Same problem here. I have tried everything from a FDR to a new sim. None of the attempts fixed anything and my phone is out of warranty. Are you still having issues after the recent system update? It is supposed to include a new system radio which may fix it??
Remmnate,
We’re happy that you have reached us here for assistance. We never want for you to have trouble with your service. Your extensive troubleshooting is very much appreciated. When did this start to become a problem? What Zip Code do you live in?
AliciaS_VZWFollow us on Twitter @VZWSupportIf my response answered your question please click the �Correct Answer� button under my response. This ensures others can benefit from our conversation. Thanks in advance for your help with this!!
From April 29th-30th through May 2nd when I switched phones. It worked about 10% of the time during those days at random times and with no common denominator. It usually worked for 10-15 minutes after a restart, FDR, or the SIM swap. Data continued to work. It was only Calls and text. Zip Code is 57108.
We appreciate you rproviding the details of your concern Remmnate. Let's continue to investigate to get to the root cause of the issue. When you performed the factor data reset, did you test the device before re-adding your info to the device? Have you noticed a pattern with the calls & text? For example, was the issue with the same numbers?
ArnettH_VZWFollow us on Twitter @VZWSupportIf my response answered your question please click the �Correct Answer� button under my response. This ensures others can benefit from our conversation. Thanks in advance for your help with this!!
