Android S III battery drain problem Fixed !!!
DanKern61
Ok, I had upgraded my S III to 4.3 and after that my battery would not last more than 4 hours on a charge.  Finally, on the web I found the fix.  Do not use the OS email apps for regular email or especially Gmail.  Uninstall those apps and down load a third party app like Aqua Email.  I did that yesterday and now my battery lasts days.  Verizon had me do a factory reset that was absolutely no help.
Labels (2)
1 Reply
cinholl07
Hi Dan.  I tried your suggestion, but I'm confused about the email issue.  I keep getting a message saying I need a backup email.  I can't access Google Play without one.  I'm not very bright when it comes to electronics.  Thanks.
