I have noticed this for a while now but it is getting ridiculous. I know folks have issues with Battery since the updates but I am also having major issues with the phone being overall sluggish (and I have not installed any new apps, etc...in fact I have deleted/removed them as my phone is so bad) as opening anything is slow, changing screens, etc. Is anyone else having this issue?
Also, I have an annoying issue as over time the lock screen where you have the numbers show up to put in your password...overtime they slowly start to turn into white blocks on my screen and you can't see them. The spots are there and you can unlock your phone but you have to know the numbers in order to do it as all you will see are white boxes where the numbers and letters should be. Anyone else seeing this?
Anyone have any tricks to fixing all the issues other than a factory reset and the pain of doing that?
