My phone doesn't ring, the calls go to voicemail.
I figured it out. My mistake. Thanks
GERHUD70, let's find out where your calls went. It would be challenging to not get your calls anymore. When did this start? Where does this happen? Is anyone else affected?
I'm having the same problem with my S7. What did you do to fix this on your phone?
I realized that incoming calls that were not blocked, that were not
UNKNOWN, but were not in my contacts were going to voicemail. This is what
I gleaned from my own investigation. So far, that appears to be what
happened in my situation. Hope this helps, by no means am I tech savvy.
Unfortunately, my problem involves my contacts too. My wife accuses me of not answering my phone when she calls. This is not good!
