  • 3.3M Members
  • 7,843 Members online
  • 194K Discussions
  • 34.7K Solutions
Keyboard and battery problems since system updated
Amylfw
Enthusiast - Level 1
Since installing G920VVRS4DRB1 on my Galaxy S6 I'm having problems with my keyboard not typing in several apps. It appears on the screen and seems to behave normally but no letters appear. I use SwiftKey keyboard. I was unable to change to native keyboard in settings.
Also experiencing random battery drain.
Labels (2)
Ann154
Community Leader
Community Leader
The keyboard issue might not be connected to the update. SwiftKey has been having issues with Chrome text boxes for a while now. To change keyboards, touch the little keyboard icon in the navigation bar to select a different keyboard.
Community Manager
Community Manager
Hello, Amylfw. Let's start by going into the Play Store, and manually checking for app updates. To check on the battery, please run a Device Health Check from your MyVerizon app.
kathy65793
Master - Level 1
After an update it is always a good idea to clear the cache partition. Turn the phone off then hold Volume up-power-home. Use the volume button to go down to clear partition press power then use the volume down key to say yes then power again. Then just hit the power key again when the phone goes back to recovery mode and reboot phone is highlighted. This will clear out any old files left from the update. It does not affect any of your phone settings that you have on the phone.
This should help with the battery drain on the phone.
