bluetooth connection issues. bluetooth will not keep solid connection even if the phones is right next to connecting device. is there a fix to this problem? we have two S4's in the the house and both have had the issue since day 1
usaf1234
bluetooth will not keep solid connection even if  the phones is right next to connecting device. is there a fix to this problem? we have two S4's in the the house and both have had the issue since day 1.
Labels (2)
stef7
Master - Level 2
Have you tried a different BT device? It could be the BT device, as opposed to the phones. BT should have a range on the order of 10meters (30ft). Since both exhibit the issue, that would be my first impression.
usaf1234
Yeah, I tried my LG surround sound at home at the same issue happens. I think I pretty much tried everything down to erasing all my Apps. and still have the same issue. I pretty sure its just the phone, I tried a coworkers S5 to the same BT device and it worked even at a 10 ft,. range
Snn5
Legend
Is the device paired with both phones, so that either phone can connect to it if it is on and the phone's BT is on?  Just thinking that there might be a fight between the phones and the BT device cant decide between the two.  I know some devices have a primary pairing and some have "a whoever connects first" kind of thing.
usaf1234
I also tried this and disconnected the BT at home from my Wife's phone and still the same. the BT headphones I just bought those about a week ago and my phone has been the only device paired with those, with the exception of my coworkers phone
