I’m in a semi-rural area with no wired internet, so getting 4G service in the home is essential.
I did a search on this topic and found plenty of complaints about 4G speed, but none that fit my situation.
NOT THE DEVICE: My neighbors and I all began having this issue across all our devices at the same time, so it’s clearly not the devices’ fault. Over the last six weeks or so, one of my neighbors has made countless phone calls to Verizon and had no luck, so I thought I’d give him a break and start my own effort online.
WHEN THE PROBLEM STARTED: Before around May 30, 2017 and for at least 2 years previously, signal strength and data download speeds were good. I never ran a speed test (didn’t need to), but I was able to stream HD video just fine. Since around May 30, the signal strength and data download speeds have been much lower, and extremely erratic.
SIGNAL STRENGTH: Before May 30, signal strength was in the 2-3 bar range (on an iPhone 6+); since then, it has been mostly at 1 bar, and occasionally is lost altogether (3G or even 1x).
FIELD TEST MODE: Only in the last week have I set my phone to Field Test Mode and begun recording db readings. Walking around outside with the phone pointed in various directions and orientations doesn’t seem to affect either signal strength (~ -100 to -108 db) or data speed in any consistent way. Data speed can be relatively fast with a weak signal, or terrible with a stronger signal.
SPEED TEST RESULTS: Extremely inconsistent, but low overall. One download speed test might result in up to 5 mpbs, while an immediate re-test might net only 0.75. At no time is the download speed ever fast enough to stream HD video.
NO CONSISTENCY: There is no pattern to the erratic speed. Time of day doesn’t matter.
BOUNCING NEEDLE: On all speed tests, the needle begins by bouncing upward quickly and then settling slowly several times — as if the signal is intermittent — before stabilizing towards the end of the test. The more frequent the initial upward bounces, the faster the overall speed test result.
UPLOAD IS FAST: The weird part is that upload speeds are consistent and excellent at 10-15 mbps. The needle does not bounce around on upload tests as it does on downloads.
SIGNAL BOOSTER: I just purchased and tested a WeBoost signal strength booster. It boosts the signal strength as advertised, but the data download speeds are even more wildly inconsistent. One speed test delivered a dizzying 20 mbps. An immediate re-test netted 2.4 mbps. Mostly the results about the same as before, and average around 2.0 to 3.0 mbps, although they range all over the place.
Ideas?
