I need a clarification about setting up WiFi calling, specially while overseas
1- Should Airplane Mode be turned on or off?
If I turn it off the WiFi Calling options are no longer available (Grayed out)
2- I follow the WiFi Calling FAQ and the part that I am not clear is in this section
"To change your preferred network on your Android device:
Go to Settings on your device.
Tap When Roaming and select the network you want to use while roaming:
Prefer Other Cellular Network (default)
Prefer Wi-Fi"
While overseas should it be set to WiFi instead of a Cell network?
3- Our son is in Europe and he turned Airplane Mode On and WiFi on and was able to get and send text messages in Barcelona.
But while in Venice he cannot get/receive text messages.
Is the problem a country/WiFi problem or he has to turn Airplane Mode Off (see question #1)
Thanks
Update
Seems to be a WiFi provider issue, he tried a different WiFi and it works
