I own a galaxy s9+ everytime I make a local call my phone asks me if I am sure I want to call a international phone number even though the number I'm calling is local and has the same area code as me
It is important that you are able to make calls, Ninjawtfbbq. Does this also happen when you call numbers outside your area code?
PeterP_VZW
My phone doesn't care if the call is in or out of my area code. It just won't connect in the house.
We will get to the bottom of this! To confirm, the calls work fine as you leave your house and travel to a different area? Are you using WiFi and WiFi Calling in your home?
YaleK_VZW
