What is better way to get the internet access with Fios installed and the Fios router (I'm gonna have
triple play bundle (tv, internet, phone) installed next week :
- Use the ethernet port and run a cat 5 cable direct from ONT to the router ?
- Use the coax port on ONT which runs to 3 TVs and splitter off coax to the router for internet wireless access ?
I was going to run/fish a cat5 e-net cable up thru attic before the tech comes to house - IF
using the E-net port works better/easier/faster all around vs coax for the internet.
Is it worth my time and sweat to do that really or just piggyback on the coax ?
I read some post that the ONT can NOT have the ethernet port and Coax port enabled at same time ?
Is that correct ?
Seems pretty bad or little value having these built into ONT and not able to use them together.
Thanks
