will have to cancel service if not corrected in the next couple of days. Both dvr and stb do it.
Not sure what you mean by "Verizon switched me to digital", but you should call support. Don't assume that they are aware of an issue that may only be affecting you and no one else in your neighborhood.
Verizon has been all-digital for at least two years.
Wrong,
I signed up for another 2 years and they said we will switch you to digital. Did not have a problem before that. Already called support. Disconnect/reconnect cables, new splitter. Their issue is out in the field.
Maybe he means Fios Digital Phone, that's the only thing they could have switched over, but that wouldn't affect the TV. As someone else said, Verizon TV has been all digital for about 2 years now. You need to just call and get a tech out to your house to see what the problem is.
With matcarl here ... Verizon TV has always been delivered digital. The OP must have had some other service change made that they are confusing with "digital". Perhaps the OP can be more specific about exactly what was changed at the home end of the connection because the TV delivery method itself hasn't changed.
