Hi all;
just bought a new X BOX 360, ive tried every single solution wireless or wired...i have an actiontec MI424wr current firmware,
keep getting that MTU incorrect error even tho i did reset it...i tried from 1364 to 1492....ive added the xbox in the router to open the xbox ports..(was a preset) have Universal plug n play on...looks like i am totally out of options..and looking at the googled question...with all the FIOS user that cant use XBOX im not alone..
also where the HECK is the direct i want to talk to someone in bangladesh FIOS support number??
Thanks
