Can someone please tell to reocrd a program from DVR to my VCR without getting all snow
Here is my set up
TV- Sony
VCR/DVD- Sony SLV-D300P
DVR- QIP7200
Well from the STB to the VCR you will have probably one of three different kinds of connections....
1. Coax cable. this will be a screw on cable running from the STB to the VCR. Single cable connected to silver posts by a screw on nut
2. A/V cables. this will be a cable with 3 colored ends...RED, WHITE, and YELLOW
3. Component cables (this one is not likely but I have seen a few VCR's that use these). This is a set of cables with 5 colored ends. RED, WHITE, GREEN, BLUE, and RED
THe cables I have
How many threads do you need for the same question? This was asked HERE and answered, but you seem incapable of taking the instructions given successfully.
Yellow from DVR Video Out to VCR Video In
White from DVR Audio Left Out to VCR Audio Left In
Red from DVR Audio Out Right to VCR Audio Right In
The inset color of the RCA jacks (color inside the silver ring) matches the cables.
Set VCR to LINE INPUT, play the DVR recording and record on the VCR. If that is too difficult then get Geek Squad or someone who understands how to connect components. The connections are also shown in the DVR manual.
I have been using this exact set of connections for 2 years and it works fine.
In order to avoid board clutter, we ask that you post your topic on one board only. As Keyboards stated in his post above, please look ---> HERE for replies to your topic.
Thank you all for your input. This thread will now be closed.
