Is there a 'fix' in the works for the Digital Optical connection and the PVR 7216? Do I need to downgrade to a PVR 6416?
When's the next update?
Thanks!!!!
@duckcougar wrote: Is there a 'fix' in the works for the Digital Optical connection and the PVR 7216? Do I need to downgrade to a PVR 6416? When's the next update?Thanks!!!!
Last i was told Verizon is not sure when there will be a fix out for the 7216 DVR, that cover all three of your threads, this one, the audio one and the Channel Unavailable thread.
The only "FIX" is to get a 6416-2 DVR. You should not consider it a downgrade. It is working way better over all then the 7216 is. The only advantage of the 7216 at this time is its SD PQ is better then the 6416, if you mostly watch HD as i do, what does it matter!
Tivo-
-- Upfront costs
-- Monthly Fee
-- Cable Card fee
-- No On Demand
-- No IMG
-- Added chance of pixellation (read posts about TIVO not handling "hot" signals)
These are all of the reasons when i came back to FIOS the Tivo went out the door.
