I'm trying to set up my computer at home so that I can access it from my in-laws, who are also FIOS customers and from my Android device via Sprint's network. Both of these use SSH as the protocol, and on the theory that port 22 might be blocked, I set up the Actiontec to map an alternate port (1977) to port 22 on my server. My first attempt was to use the port forwarding capability in the router, but I have been unsuccessful in establishing a connection from outside my network.
I've tried configuring my server as the DMZ for the Actiontec, which makes me nervous, but I was running out of ideas. I even turned the firewall off on the PPoE connection but that didn't help either.
From outside my network, I can ping the WAN IP address assigned by Verizon to my router, so inbound ICMP packets are OK, at least as far as getting to the Actiontec
I can log onto my server while on my local network, but not from outside the network.
I'm running out of ideas. Does anyone know of a way to dump packets coming to the Actiontec so that I can tell if the inbound TCP packets make it to my router?
Does Verizon block inbound TCP requests for residential service? For all ports?
Thanks for any info,
Joe H.
{edited for privacy}
