I have discovered an issue with Windows 7 64 bit OS. My attempted set up was to havea 802.11n Belkin Play router connected to my Actiontec MI424WR router as a wireless access point with the MI424WR wireless radio turned off. This worked fine for my XP 32 bit PC, my Windows 7 32 bit PC, and my 2 Windows 7 64 bit laptops using wireless. A problem arose when I tried wired connections on the Windows 7 64 bit laptops and a Windows 7 64 bit PC.
While wired, internet would drop either completely or intermittently but too frequently to be useful. Tech support had no idea what to do or what caused it. It was reproducible after a reset of the router and then turning off the wireless radio.
I could fix it by turning on the wireless radio again, but I had hoped to turn it off and only use wireless from the 802.11n router.
Any ideas?
Brian
