Hello All,
I had FIOS TV installed yesterday and encountered a couple of issues immediately.
First, I was told by various Verizon people that the HD-DVR that I would recive would support OTA antenna. My Cisco HD-DVR dones't and the Verizon Tech/Installer didn't think the Motorola HD-DVRs that are being phased out do either. How could they not support OTA antennas? Any add on modules available?
Second, the FIOS picture qualtiy color and sharpness wise is not as good as a over the air antenna set at the same channel. The Verizon Tech was dumbfounded and said he would have never belieived the difference but he couldn't argue with the on scren results. Why the degraded picture quality if Verizon is not compressing the signal?
Third and most important, I loose audio on the RF output if the HDMI port is plugged into my TV and the TV is turned off. I have a Panisonic Plasa TCP54G25 TV that is directly connected to the Cisco 435 via HDMI. I have tried both HDMI 2 and 3 on the TV side. I also have a VCR connected to the Cisco 435 via RF output and RG-59 or RG-6 cable. If the TV is on, the VCR has audio. As soon as the TV is turned off, the VCR looses audio until the HDMI cable is disconnected or the TV is turned on again. I've tried the mute button, changing channels and been through the Cisco menus 5 times with no solution. Can anyone help?
I appriceate any help or feedback that anyone can offer.
Thanks...
Neil
