I connected a second wireless receiver to the kit and updated all of the firmware on the new hardware.
When I connected the second wireless receiver to my existing set up, I received a picture on all 3 TVs briefly and then a big BLUE banner on all TVs indicating "THE HD CONTENT OF YOUR REPEATER HAS BEEN COMPROMISED..... <couldn't get any more than that before all pictures went scrambled>.
I read that there is a potential problem with how the Motorola 7000 Series are interpreting the HDCP protocol; Something about throttling to max 2 connections when the technical specification calls for 7......
Others have said that a simple update to the firmware/version of the DVR/STB will fix it; However, I'm already running 1.9.1.
Does anyone have a solution to fix my problem?
I guess a solution is to run a dedicated HDMI cable out to the TVs but if the system is going to throttle at 2, then i'm still anticipating the same problem with the choke point.
Technical Details:
Motorola DVR: 7232-2
STB Model per the widget: 7216
STB Software: 1.9.1
Actiontec MyWireless TV: MWTV200KIT-01
Actiontec Receiver: MWTV200R (all running same firmware version and latest from Actiontec)
