My TV went up and now I am using a TV that is a Sanyo model that has only cable input. I would like to connect my Ruko using Verizon cable box. Does anybody know if this is possible and how to do this?
Thanks,
Inputs on verizon STB are not enabled.
Do you happen to have an old VCR or DVD player that has inputs? If so, can route the roku through there.
Another option is to get a adapter that converts composite video and audio to a channel. Put it inline w/ cable to TV.
May have to power off Roku to get it to switch back to cable depending on the model.
