lTV and cable DVR were unplugged. Plugged back in and nothing is working only message on DVR E 11. Please help
You may be out of luck, as I think the error code signifies that the box needs replacement.
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Boot_Error_Codes
Obviously, you could try a live chat on these forums to try and recover the unit through some resets by VZ, but the code suggests otherwise. Might be worth a try.
If you have a local walk-in store nearby, I would recommend exchanging that way as it has always been a more rewarding experience for me. Good luck.
