Recently I have been having problems with the channel guide for FiOS TV. However, it's only with the one TV. The other TVs in the house are fine.
So what the problem is, is when you press the "Guide" button and it switches to the channel selector screen it doesn't list what show is playing or the description. It just says "Please wait..." For every single channel. And then if you select the channel...it says it can't find the program. However, if you type in the channel number it will go to the show. Occassionally, it's been cutting out, too. I'll be watching a show and it will cut out. Sometimes it comes back. Other times I just have to switch channels, then switch back and it will play again. And maybe it's worth mentioning that this has been going on for a week.
Like I said - it's only happening on one TV out of 4. Any suggestions?
And I also need to say, I really hope FiOs changes the guide menu. This new one is awful.
Thanks.
