Background: Until the other day I had my stb connectected to a TV, using TV sound, with an HDMI cable. The P265v2 remote volume control changed the TV volume. No problems.
My new TV & home theater system was recently installed. We don't use the TV speakers. While my first preference was to program the Verizon remote to change the volume on my Onkyo receiver, this did not appear to be an option on the remote's programming instruction page on the Verizon website. Instead, I am directed to change a setting on the remote that makes the Verizon remote change the stb output volume vs the tv volume. I changed the setting on the remote and ensured the stb box was set up for "variabe" audio output.
Problem: Using the stb variable audio settings, volume settings 1 through 30 produce the same volume. (Volume setting 0 produces no volume, as one would hope.) It appears the "variable" setting isn't producing a variable output as it should be on this unit.
Thinking that maybe the receiver was complicating the sitation, I tried connecting the stb to the old TV and the new TV directly and had the same results.
Now, while I am watching TV, I need to have the receiver remote at hand in addition to the Verizon remote. It would be nice to have the volume be adjustable as it should be while using the Verizon remote. I don't like the idea of using a seperate universal remote because then I would lose some of the functionality that the Verizon remote provides when watching TV, using the DVR, watching on demand, etc.
I would like to know if this is a problem just with my unit, or if it exists with all of these units, which would hopefully be fixed with a Cisco/Verizon firmware update soon, hopefully.
Thank you.
