Our BBU is intermittently beeping to indicate an aging/low battery, but we no longer have voice service as part of our FIOS package, and therefore the BBU serves no purpose. Therefore, we tried to disconnect it via the online instructions. However, when we do that, our internet no longer works. How can we stop the beeping and keep our FIOS internet functioning without paying $40 for an unnecessary battery?
Some background:
We initally had FIOS installed in 2010, with voice and internet services. The ONT was installed on the outside of our house, with the BBU in our basement, plugged into a nearby outlet. After a few years, we switched to a different internet provider but this hardware stayed in place.
We eventually switched back to Verizon FIOS for internet only (no voice). Verizon sent us a new router, we hooked it up, and bingo, our FIOS internet was up and running again, simple as that.
Last week, our seven-year-old BBU in the basement began to beep intermittently (every 10 minutes maybe) and display the "Replace Battery" light. Since we don't have voice service, and the BBU is only there to provide power for voice calls during power outages, we consulted the Verizon website about how to eliminate the BBU from our setup.
According to Verizon, "If you do not have landline voice service through Verizon, or if you do not need your fiber voice service during a power outage, you can safely and easily disconnect the backup battery from your Fios ONT to ensure the battery alarm will remain silent." [https://www.verizon.com/support/consumer/battery-backup/beeping]
This sounded great, so we unplugged the BBU and took the battery out, according to the instructions. [https://www.verizon.com/support/consumer/battery-backup/backup-unit#disconnect] However, our internet service no longer worked. We plugged it back in and the internet came back, but so did the beeping, whether or not the batter was actually installed in the unit.
We have gathered from this experience that power to the ONT is supplied through the BBU at all times, and also that the BBU will beep unhappily whether the battery needs to be replaced or is not there at all. Since we can't disconect the unit as stated on the website, how do we silence it permanently?
