I need to change the power strip my router is plugged into. if i unplug the router will i lose any data or settings? i dont want to undo anything - does unplugging it reset anything?
@rgarx2 wrote: I need to change the power strip my router is plugged into. if i unplug the router will i lose any data or settings? i dont want to undo anything - does unplugging it reset anything?
Unplugged it will not lose your settings etc. only pushing the reset button will wipe it.
