I need some help from the public on which external systems would work best with the FIOS STB.
Here is a list of my requirements:
1. I would prefer a 5.1 system with wireless sub woofer and rear speakers
2. The audio level must be controlled by the FIOS STB remote
3. Willing to spend up to $1,000.
4. The speaker system has to have it's own amp.
5. The sub woofer should be powerful and with good low frequency response without cabinet buzz nor distortion at higher volume levels.
6. I will settle for a 2.1 system
7. It will be paired to a Samsung 7 series smart TV.
8. Would it be better to use the optical connector on the STB or the ARC HDMI on the TV?
