I owned more than one G1100 so I tried to set one up downstream of an SB6183 Docsis 3 cable modem. It has a lot of good features including 802.11ac. However, a device called the OBI 200, which worked flawlessly when the G1100 was connected to FIOS via the WAN port - lost all ability to communicate with the internet once the SB6183 was providing the broadband to the G1100.
I can't imagine this is a firewall issue or it should have filtered the OBI packets regardless of what was happening on the WAN port. Do I have one too many DHCP servers coming into play? I thought the G1100 was smart enough to get an Optimum IP address through the cable modem and still provide DHCP to all of the connected devices. Most devices I connect are working fine - both cable connected and via WiFi - all getting IP via DHCP from the G1100. I connected the OBI directly to the cable modem to make sure neither the SB6183 nor the cable company were blocking the traffic.
Any thoughts?
Thanks,
