Just had fios gigabit connection installed with static IP address. Do speed test from PC that can support gigabit but get low speed. Will get different results like one test show 676/463, as it testing the speed go higher but drop back down. Did get one test from same PC later that day of 863/588 Called Verizon did some testing with them. They saw the low speed test they worked with network engineer and said there was problem, tech came out next day and did test from router, the verizon tech got 721/922 on his tablet. He said that over 700 was good for the service. We called Verizon they said minimum download should be 750 waiting for tech to come out again has anyone had this problem?
