When going to Channel 838, Netflix, there is no way to search for a show/movie. The remote control jumps out of channel when you use most buttons. Where is the user guide to control the remote control when on channel 838, Netflix (widget)....
JAS
The 4 directional arrow buttons will be mostly used to scroll through movies and show categories. The Play,Pause, Stop will be used to control your show.
