Hello. I started up with FIOS tv last week. Was not home during installation. The tech hooked up an IPC4100 (mini) to our main TV with HDMI cable. However, we have a home theater setup in that location that we used with our prior service but he ignored. It has an older Marantz receiver, that has an AC-3/PCM optical input port that I used in my prior setup. I saw an optical out 3.5mm port on the back of the IPC4100 so purchased a Toslink to mini-toslink optical cable, plugged them in, but no sound. Is there a setting that needs to be changed to make this work?
BTW, he set up a VMS4100 DVR on our second TV (that has no home theater setup). I see that box also has an optical out port (standard toslink) just in case swapping the boxes would help.
thanks
