Just starting having this problem when I turn on the TV I will not have a picture sometimes I will have sound and if I unplug the hdmi from the set top box and plug back in everything will be ok if I turn the box and tv off again I have to do the process all over again. The box is a 7100-2 I have hdmi from box to soundbar then to tv, this problem just started a couple of days ago and it has been hooked up like this for a long time with no problems ,Verizon is no help as they did reboots which I have done and I also replaced the hdmi cables. I did change out the to the other box that has the time display on the front and that works it's just the boxes that don't have the time display.
