We've had the Verizon 1.5-3mbps Residential DSL for years and we've consistently had download speeds that never exceed 200kbps. We've called customer support and they've run all of the line tests (which always come out fine) and then they make a call to the local center, who then leave me a voicemail a day later and tell me that I should see speed increases within the day. Of course, the speed increases never happen. So, now that's getting to be an issue to even watch a standard def Netflix movie without buffering issues, I'm beginning to lose my patience and hoping to find some relief in this forum.
Here is (hopefully) all of the relevant info:
- Actiontec GT704-WG modem/router (firmware version 3.20.3.3.5.0.9.1.3)
- Both my roommate and I are using Macs running OS 10.6.7 (I'm on an iMac and she's on a Macbook Pro -- both with Airport Extreme; we've had this issue using every operating system since Tiger, and also using different Macs throughout the years)
- We're both running wirelessly, but we have the same speed when we're plugged directly into the router via ethernet -- we see no increase by being wired in.
- We use the OS X app-specific firewall, though we've also turned it off to no effect. Also, no other security or virus-protection.
- WEP security
- The modem/router always lists our current down/up speed as: 1792 / 448 kbps. Again, while we never exceed 200kbps download, we actually achieve about 350kbps upload.
I'd be happy to supply any other necessary information. Hope someone can help. Thanks!
