I just purchased the 1.1 - 3.0Mbps hi-speed DSL package.
Verizon speed test shows .17Mbps down and .536Mbps up. This is obviously curious for two reasons: 1) the incredibly slow down speed, and 2) the down speed being slower than the up speed.
Curiously, speedtest.net shows different results:
2.45Mbps down, .55Mbps up
What could this mean? Transceiver data follows.
Transceiver Revision 3.3.6.10.0.1
Vendor ID Code 4D54
Line Mode ADSL_G.dmt
Data Path FAST
DSL Speed (Kbits/Sec)
Down Stream Path 3360
Up Stream Path 864
Margin (dB)
Down Stream Path 27.1
Up Stream Path 16.0
Line Attenuation (dB)
Down Stream Path 20.1
Up Stream Path 8.0
Transmit Power (dBm)
Down Stream Path 6.8
Up Stream Path 11.9
Thanks in advance for any advice/ assistance you can offer. This is extremely frustrating.
M King
