After removing my Samsung soundbar from my Samsung tv, I am using the TV’s speakers, however I have to crank up the TV volume to almost 100 to hear anything reasonable. I replaced the hdmi cable and swapped out the inputs to the TV. The sound is great when just using apps like Netflix. It seems that the sound level is low when going through the STB on cable channels. Is there some setting in the user menu? I have pcm setting under the hdmi settings.
