Hard Wired Ethernet computer to router has expected Gigabit speeds of over 800Mbps down and up.
Wife Speeds are significantly slower. Testing from 3 devices within 5 feet of the router are all about 400Mbps down and 150Mbps up.
All using SpeedTest.net App (Ookla) to Verizon server 4 miles away
Mac Studio 2022 Ethernet Cat 5e to the router is as expected.
800Mbps down and up
Mac Studio 2022 Wifi 6 and 5GHz
MBP 2020 Wifi 6 and 5GHz
iPhone 14 Pro Wifi 6 and 5GHz
all show about 400Mbps down and 150Mbps up
Using Verizon Home instead of SpeedTest.net
about 940Mbps down and 910Mbps up
Why are Wifi speeds so slow compared to Verizon Home (wifi)?
I know the test methodologies are different but the results should be that far apart especially when my wifi tests are to a nearby Verizon server.
BTW I did use several other speed tests including CloudFare and several others and all have similar results.
