Tried to use conference with 2 other lines following the directions in the guide.
Initially the 3 way conference worked fine then the second line, the line I called to set up the merge call sequence, went partially dead in that the second phone could not hear the other 2 people but could still be heard. This occurred no matter which line was the second line called. Does anyone know of this problem and what the solution might be.
