With my previous Verizon 3G modem and Cradlepoint wireless router (MBR900), I was able to access my WiFi camera from anywhere using a smart phone or computer. I used dyndns.org to set up a static IP. Now I upgraded to 4G (Pantech UML290) with the same router and now the remote access to the camera no longer works. After many wasted hours trying to figure out why, it appears that the problem is the way the Verizon 4G works. The IP address is private instead of public, so incoming access is blocked. Is this correct? Is there a work around available or planned to correct it? The ability to check the camera video from anywhere is important to me. Is the only solution to drop 4G?
I have seen discussion of solutions (like bridges) that work for allowing remote access to computers, but that doesn't help me with access to this camera (Foscam) that has an internal server.
Thanks,
Terry
