Our home phone connect will not ring our phone periodically ( couple times a week at least). When you call it rings and eventually goes to voicemail. This has been an issue since I started using the service July 2011. We have tried moving the device, updating the PRL, exchanging the device for a Refurbished unit, unplugging the power, and pulling the battery. Verizon has checked cell strength and has found it to be excellent. I am at my wits end. The problem can't be replicated at will, it happens whenever. I have one last attempt in to have them actually check the call logs to see if the calls are actually being received by my modem. Otherwise Verizon thinks it may be my cordless phones since some phones don't pick up correctly supposedly. Now, my contention is this, my phone is electronic, if there was an issue it would not magically get better, it would stay broken. You can literally call one minute with no ring into the house and the next minute call again and it rings. This leads me to believe that it is the modem and not the phone. Verizon wants me to spend my money to replace the phone to see if that may be the issue. Ummm...NO. My phone worked fine before. Verizon says this is supposed to replace my landline, therefore it should work with my existing equipment.
Now I am out off the warranty period so I can't get another refurb unit ( they would not give me a new unit at all, I suspect the refurbs have this issue, hence refurb) even though this issue has been documented since I had the unit. My solutions are : Verizon sends me a new unit free of charge or Verizon sends me a cordless phone that they know that works to see if the problem goes away or I start discussions with verizon about leaving and getting money back since this is not home phone connect this is home phone connect mostly...this type of service NEVER EVER happened with the landline.
So I am asking for anything obtuse in help that may not be in the troubleshooting charts but might fix the issue or someone from Verizon to make this right. I have been VERRRRRRRY patient this last year troubleshooting but time is up. I have kids that I need to be able to contact.
Thank you for your time in reading this.
Wacle
