I have ordered the s6 edge at full price from Verizon so I can keep my current plan, which has unlimited data. What do I need to do when I get the new phone?
Take the Sim out of your old phone and stick in the new one. That's pretty much it. You may need to activate the Sim that comes with the new phone if they are a different size. Just log into MyVerizon and activate it following the instructions.
Thanks. So the sim card from the S4 will fit into the S6 Edge?
Don't think it will I believe the S4 is a micro sim while the S6 is a nano sim? You should get a sim in the box either way.
