I've uninstalled all recent apps installed. This has not corrected the problem.
I've installed a virus scanner, no virus' found.
Explain next steps to fix.
Perform a Factory Data Reset (Device Powered Off) DROID RAZR HD / RAZR MAXX HD by MOTOROLA | Verizon Wireless
What device?
Android Razr HD Version 4.4.2
Anything else I can try before doing that? I'll loose all my apps and data if I do a reset.
Thanks for bringing your device concern to our atention littlefury. Let's partner together and get your Droid Razr HD working properly again. May I ask what the last action taken before the device reboot? If there 's any physical or liquid damage on the device? Have you already completed the factory date reset? If not then we encourage you to do so and retest the device without adding your info and 3rd party apps back to the device. If you can keep us posted then that would be great.
ArnettH_VZWFollow us on Twitter @VZWSupport
