Ever since the 2.1 Android update to my wife's HTC Droid Eris phone, there is a problem of the phone constantly running sync over and over. It drains the battery quickly. If I go to Settings...Accounts & Sync, it shows Sync completing and then starting again, again, etc. I went into Gmail Sync and it seemed to show Contacts and Calendar syncing over and ove. If I am in the main sync page and hit Cancel Sync, it stops the problem...for a while. It could be an hour, it could be 8 hours, but it always has the problem again at some point. I did a search and could not find anybody mentioning this problem. Does anybody have any suggestions? Is this a known issue? I would rather not try the factory reset route if at all possible. Powering off the phone does not fix the issue. Thanks in advance.
