This is an odd one to me. Im having problems on my S6 Edge on my HOME Wifi only. And, only with specific apps.
Apps like SnapChat, Facebook, Netflix, refuse to load on my home network. Whether i use 5Ghz or 2.4Ghz makes no difference. They all work fine on any other WiFi network i connect to, and fine on 4G.
If i put my phone into Airplane mode, then connect to my home Wifi, everything again works perfectly. I dont understand this!
I have spend hours troubleshooting, going through all the normal steps regarding the phones settings, reboots etc, and have tried multiple different things on my Router. The fact that everything works on Airplane mode leads me to rule out the router completely, and point a finger at the phone again.
I cant 100% pinpoint when this started to happen, as to start with i just assumed it was just my TWC internet being as reliable as TWC is in NYC. But this problem did not happen when i first got the phone, and there has been one or two updates pushed OTA, recently-ish. And im generally a believer in if something worked fine before, and the only thing that changed was an update, then this is probly where the problem lies.
Thanks, and i appreciate any suggestions.
